Στο forum του shipspotting έχει γραφτεί ,
Atlantic Freighter sold
I heard now she is leaving Port aux Basques under her own power and will leave Friday, and she has been renamed Pegasus (not sure if thats the correct spelling)
Μήπως έχουμε βάλει το χέρι μας σαν Έλληνες να έρθει το πλοίο από τον Καναδά στα λημέρια μας;
_____________________________
(1978, ex-Tor Felicia, Merzario Grecia, Stena Grecia, Atlantic Freighter)
  • Replies 403
Τελικά επανέρχονται στο forum του shipspotting (και με φωτό), αναφέροντας ότι το νέο όνομα του πλοίου είναι PELAGITIS, οπότε καλορίζικο, αλλά για ποιον;
Ας δουμε τι λενε και οι Lloyd's:
02 April 2010, 08:09
Pelagitis (Panama)
London, Apr 2 -- A press report, dated Apr 1, states: Roll On Roll Off Pelagitis, that ran aground in Port aux Basques harbour Wednesday afternoon (Mar 31), has been towed out of shallow waters by a tug boat. The vessel was driven into the rocks along the shore line by high winds as its new crew tried to leave the harbour for the first time. The vessel's new owner, a Greek company, says there's no apparent damage. The ship's crew will be thoroughly inspecting the vessel before it heads out onto the water again.
01 April 2010, 21:28
Pelagitis (Panama)
Kiel, Apr 1 -- Roll On Roll Off Pelagitis which grounded at Port aux Basques on Mar 31 has safely made it to the dockside once the sea levels rose with the following high tide. -- Correspondent.
01 April 2010, 08:09
Pelagitis (Panama)
London, Apr 1 -- A press report, dated Mar 31, states: Roll On Roll Off Pelagitis (13117 gt, built 1978) has run aground in Port aux Basques. It was unclear exactly what happened, but officials from the Coast Guard Marine Traffic Centre in St. John's said high winds appeared to be at fault. The accident happened in the Port aux Basques harbour.
believe we'll see her in Pireaus, greek owner... any info??
searching and surfing, i noticed, she has a story with asbestos, never removed but covered in a way.
Δυστυχως ακομα δεν φαινεται στα registries ποιος ειναι ο πλοιοκτητης.
Ακούστηκε πως Χιώτες αγόρασαν ro/ro από Πειραιά ή Λαύριο για Σάμο-Χίο-Μυτιλήνη... μωρέ λες?:confused:
Μετά από μια μικρή στάση στο Algeciras το πλοίο μπήκε στη Μεσόγειο και έρχεται με αναγραφόμενο ΕΤΑ 24/04 ώρα 10:00 στην εξωτική Χαλκίδα.
Edited by enas chiotis
Σήμερα ο ΟΛΠ το αναγράφει στα αναμενόμενα για τις 24/04, με σημερινή ημερομηνία αίτησης, άρα θα περάσει και από τον Πειραιά πριν πάει Χαλκίδα. Αυτη τη στιγμή βρίσκεται νότια της Σικελίας.
Στα της ιδιοκτησίας, έχουμε διαχειρίστρια την εταιρεία COMMERCIAL SA με διεύθυνση 24, Kyprou Street, Glyfada. Στο στόλο της έχει 10 ψυγεία, 2 containerships και 1 γενικού φορτίου.
Έφτασε και έδεσε στο Νέο μώλο! Προσωρινά και θα φύγει για Αυλίδα ή αλλάξανε τα πλάνα; :confused:
Στις πιο πάνω φωτογραφίες μπορείτε να προσέξετε ότι έχει δυο ξεχωριστούς καταπέλτες στη πρύμη. Ένα για το main garage και έναν άλλο για το upper garage, όπου ο ένας είναι πάνω από τον άλλον
Πραγματικά εντυπωσιακοί οι καταπέλτες του, αλλά δυστυχώς χωρίς φωτογραφία μιας και βρίσκονταν δύο τρία φορτηγά στην πρύμη του. Σημερινή φωτογραφία από πλώρα, στον ΝΜΔ.
Το πλοίο έχει δέσει δίπλα από μια δεξαμενή των Ναυπηγείων και έχουν ξεκινήσει οι εργασίες στο πλοίο. ήδη γίνεται αμμοβολή στις εξωτερικά στις λαμαρίνες αλλά και στο γκαράζ. Το πλοίο θα παραμείνει λογικά στη Χαλκίδα περίπου 3 εβδομάδες.
Στο Pelagitis θα γίνει σε όλο το σκάφος αμμοβολή και όταν θα ανέβει στη δεξαμενή θα γίνει και πλαστικοποίηση των υφάλων. Ενώ θα γίνει μετατροπή καυσίμου που καίνε οι μηχανές του (πριν έκαιγε Diesel και τώρα θα το γυρίσουν σε Fuel).
Στον οποιο PELAGITIS γινεται της κακομοιρα απο εγρασιες.
Υδροβολη ή αμμοβολη γινεται μεσα στο γκαραζ ενω σε πολλα σημεια εχει μπει μινιο.Κουκλι θα βγει το βαπορι τελικα
Αν προσεξει κανεις στην πλωρη υπαρχει ακομα γραμμενο αναγλυφα το GRECIA απο τα προηγουμενα ονοματα που ειχε το πλοιο
Σήμερα το Pelagitis έπεσε από τη δεξαμενή των ναυπηγείων της Χαλκίδας ενώ το πλοίο σύντομα θα σηκώσει Ελληνική σημαία.
Εάν δε κάνω λάθος στο Καναδά άνηκε σε δημόσια εταιρεία με αποτέλεσμα το πλοίο να είναι γεμάτο από ανταλλακτικά (συχνό φαινόμενο σε πλοία που αγοράζονται από το εξωτερικό αλλά όχι όταν πουλάμε εμείς στην Ελλάδα)
Πως είναι δυνατόν να νηολογήθηκε στη Χίο 1η Ιουλίου και ο Neptune να το έχει πει από αρχές Ιουνίου; :confused:
